Re: Unsticking Old Rusty H With Hydraulic Jacks??
Redfan
05-26-2001 04:29:52
I had a similiar problem with a 15-30 Red. The pistons came out but the sleeves were well stuck. I placed a heavy beam under the tractor, tied a high tensile chain around the beam and secured it to the tub of the 15-30. A 20 ton jack was used between the beam and the sleeve. They all come loose, but two of them took all twenty tons and all my nerve to crack them loose. Went off like a 12 gauge. Perhaps you could use a similiar setup on the bottom of your pistons. Regards, Redfan.
The Red
05-26-2001 04:34:38
 Re: Re: Unsticking Old Rusty H With Hydraulic Jacks?? in reply to Redfan, 05-26-2001 04:29:52
Thanks RF. This engine had a rebuild and then got stuck not too long afterwards. Now that might have been 10 years ago. If I can get the pistons out, I will probably just hone the sleeves. They have little to no wear.
