Timing
Author |
JAW
05-24-2001 17:33:09
I would like to know if I can use a timing light on my SM farmall.I would also like to know were to set the timing to get the best torque.
Havin Fun in Mo
05-25-2001 15:56:46
Re: timing in reply to JAW, 05-24-2001 17:33:09
I can think of no reason why you couldn’t. You would have to have a pointer and mark on the end of the crank that were set at TDC on the number 1 cylinder. A timing light with a dial advance would make this a lot simpler other wise you would need timing marks on the end of the crank as well. I can’t help you with a timing setting. I would do it similar to a Hi-performance auto engine. Set the engine at around 1000 RPMs under a slight load and turn the distributor to get the highest power and vacuum readings. Use your timing light to check where the timing is set for future reference and lock it down. Be careful not to advance the motor to far. Use as little advance as will get you the maximum power/vacuum.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
