Re: Proper Torque Specs. for Manifold and Head on a Farmall C
Author |
Haas
05-24-2001 05:52:38
Don't know about the manifold. I had some leakage from the head gasket on my C. Folks on this forum said the correct torque for the head bolts was 65 ft-lbs. I asked the IH dealer and he said 80 ft-lbs. Don't know which is correct, but I tried 65 ft-lbs first. The bolts all moved at around 40-50 ft-lbs, so they were not tight enough. However, the leak did not stop until I went to the 80 ft-lbs.
Fatback
05-24-2001 10:01:51
Re: Re: Proper Torque Specs. for Manifold and Head on a Farmall C in reply to Haas, 05-24-2001 05:52:38
Thanks HASS, I want to put her back together this weekend and test her out. Had some oil in the radiator not much just a skim, hopefully it was caused by a bad head gasket. Did not have any water in the oil. Sleeves are in very good shape honed them and installed new rings. Everything else seems to be alright as of now. Thanks again "Fatback"
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
