Fired up the SWD9 yesterday and it seemed to be running almost okay. Kind of sounded like 1 cyclinder was not running real smooth.
Hooked up to a trailer with my Bobcat excavator on it and headed down the hill to the neighbors. By the time I got to the bottom of the hill it was running rough and lots of white smoke out the exhaust. Made it to the neighbors a half mile away.
Finished helping the neighbor snd loaded up.
Started it on gas and it ran smoothly, switched over to diesel and it was running rough.
Headed home and pretty soon there was periodically fire out the exhaust. You could see the flames. Also engine temp got hot. Plenty of fluid in radiator. Not a lot of power at this point.
I got it home now.
So where to start?
Injectors or injector pump?
Timing on diesel side?
Bad compression?
Valves?
Head gasket?
Cracked head?
Thoughts on where to start or what has occurred on these engines in the past?
I got it home now.
So where to start?
Bad compression?
Valves?
Head gasket?
Cracked head?
