This is specific to my 300U, and I'm not familiar enough with other models using the fast hitch to know if the geometry is similar...
But is there a good method for adding sway chains for lateral stability of the fast hitch when used with the 3 point adapters? At fixed height with a drawbar the flatbar stabilizers work fine, but what if you want to still adjust height with a brush hog or box scraper? The lateral link takes a hell of a side load.
Ideally you'd like to have the anchor point of the chains in the same axis as the front pivot of the 3 point arms, but the fast hitch puts that very far forward.
