Still being tortured by my IH 504 Utility with clutch issues. Clutch disc and pressure plate replaced ,splines on input shaft cleaned up,disc slides freely on
imput shaft.Only way it will go in gear without grinding is to remove floorboard to allow extra clutch pedal travel. If I adjust linkage per book the three
fingers on pressure plate are lightly touching the release bearing and its turning with engine, If I back off the adjustment a little then the clutch wont release
enough to get it in gear ..Two questions, can a flywheel be resurfaced so many times that the reduced thickness throws off the geometry of the linkage. Step is
correct,have no info on min thickness.. If this is the case,can the 3 clutch fingers be adjusted to help compensate for this. Tractor is useable now but not very
convenient.Yes,flywheel was resurfaced before clutch install.
