TD340 Crawler
BillieS
New User
Hello all, I was wondering if this section of T,TD 340 is still alive? I recently purchased one, TD340 D166 engine with
6 way blade and am in the middle of draining all the fluids and change all filters. If there are any on here left I would like to have a
wiring diagram as I am going to have to replace some switches and some wires. Not sure how to find out what year it is.
Thanks
Billie
Hello Billie welcome to YT! Here is a wiring diagram for you, just make sure you are on the right page. I take it that this is a running and functional machine. Please remember to use it for 40hp tasks and not like a 100hp machine. Good advice by Barnyard about the manuals.
Wiring diagram
Thank you Red MN. That is excellent advice. I only have a 10ac farm with 20 goats and three horses. I will mostly use it for maintaining my road to the farm and the house. I have a few places I need a few small trees pushed out and leveled that is about it. Currently it is running. I had to get the fuel injector pump rebuilt due to it setting for 5 years. Right now I have it apart to change all fluids and filters. Adjust what needs adjusted, lube where it needs it. Thanks again for the diagram.
Billie
Thank you. The guy I bought it from gave me the service manual. So I am not sure what may be missing in the operators manual. My service
manual did not have the wiring diagram.
Billie
I still need a picture of the dash/console. Most everything works as far as the gauges. i.e. Fuel, Oil pressure, RPM gauge, glow plug meter. I have what appears to be a broken fuse holder on the dash. Not sure what size it is. Short of that I will replace the ign. switch with just a on/off rocker switch. Thank you again.
Billie
So I can get an owners manual for this here? Would I need it since I have the service manual?
Thanks again.
