We are having no luck removing the brass insert for the temp sensor. We are going to give it one more try which will either remove it or break the easyout. If we break the easyout my plan is to remove the exhaust manifold (has a sizable crack) then remove the head and have a machine shop remove the insert and any bolts we break on the exhaust manifold and have the head milled.
This website lists a head gasket kit for C291 or C301 gas engine - then also lists the 460 tractor. Will this kit work on the C221 gas engine?
https://ytmag.yesterdaystractors.com/Farmall-460_Head-Gasket-Set_VGK7799S.html
I hate going through all this work for what should have been a 15 minute job but that how it goes...
