International 300 Utility the way to check oil level
Dick Chapin
New User
I'm looking for some help in the way to check oil level in my 300 utility serial # 22772 SJ. This tractor has a front mount PTO I have the manual, but the pictures are really fuzzy. ....
What oil do you want check - engine, hydraulic, transmission, rear pto if you have live pto, not sure how a front pto is set up.
Hydraulic under the seat with a dip stick HyTran fluid. Engine With a dip stick 15w-40 diesel grade oil (yes). The transmission near the right foot plate a plug needs to
be within 1/2 inch of the threads. (Hytran Fluid). PTo (if live PTO) a plug (hard to get at) between the PTO and the hitch cylinder. Fill is the Peanut shaped cover,
Hytran is the fluid. Jim
