My 47 M has started flooding out when trying to start. It used to start well and even need a little bit of choke to get it running. Now as soon as I try to start, it doesn't want to fire and gas starts to drip
out of bottom of carb. I normally have the gas shut off between use, so whatever is happening is happening as soon as the gas is turned on. Once I'm able to get it running after a lot of cranking and little to
no throttle, it runs well. I'm thinking it's either a stuck or gas-logged float...other thoughts?
This post was edited by Kerwin on 09/12/2022 at 05:33 am.
