What does this crank fit?
redtom
I have this crank. It's too big for a W6. I'm thinking W9 or TD crawler of some size. Cup has a number but net didn't have any info on what the cup fits. Round guide is 2 3/4 in dia.
The ratchet, for which the part number is showing, is common to the 6-series and 9-series. Apparently it is for W-6 through 660. I can't speak to the handle end of it which was not shared through all those models. Since you say it won't fit a 6, it must be for a 9-series.
w4, w6, w9. all use a different crank. and the 560 660 engines use a totally different crank,... which is the same as the massey 44. i would put my bets on that being the w9 crank. it has a longer swing.
