Super MD wide front axle
Hi all
Will a 806 wide front axle bolt up to a super MD
It looks to big to me but I don t know
What models will work on the MD
Thanks for any advice
Yep,sure will. However,you may have to drill four 1/2 holes on the underside frame rails for the stabilizer.Many M/SM are running around with the newer style(560 to 1256) front axle.
The saddle that goes between the wishbone and the frame
rails is taller on the 806 but everything else should interchange
