Removing Super A Hydraulics
coaklnic000
New User
This message is a reply to an archived post by IHRedRules on February 13, 2010 at 13:52:42.
The original subject was Re: Removing Super A Hydraulics.
How did you remove them ? Was it easy? I don't have a use for the hydraulics on my 1949 Super A. Thanks
It is easy. Find a blanking plate from an engine (like a power unit) to cover the front cover hole (the drive for the pump). Remove all hydraulic components. Make a rear tank support as needed. But!! why reduce the value of the tractor it harms very little and is not in the road of much. Jim
On my Super C I took the gear off the pump & left everything else the same. If I need the system working again, all I have to do is replace the gear.
