Re: about to give up
- -engine
George Willer
05-23-2001 07:44:18
Gene,
You have had many good responses, but none have commented on the importance of correct valve clearance. (some have even suggested the opposite) You don't seem confident yours are right. Spend a little time there. The proper clearance has an effect on valve TIMING! If the clearance is too much...the valve will start to open later, and will close earlier, therefore it IS important.
I'm unfamiliar with your tractor, but it should use the same procedure as other 4 cylinder tractors (if it is a 4 cyl). With #1 piston on TDC on the compression stroke, adjust valves 123&5. Rotate the engine 180 degrees and adjust valves 467&8...valves numbered from front to rear. By doing it this way, you can be sure the follower is opposite to the lobe on the cam.
Just to eliminate the possibility of sticking valves, lubricate the stems with your favorite magic potion while you are there.
George Willer
Gene
05-23-2001 10:49:09
 Re: Re: about to give up - - -engine in reply to George Willer, 05-23-2001 07:44:18
George W:
Thanks. I am not a mechanic and wasn't sure about the wider gap effect on anything, certainly not the timing of the valve. I had hoped to find them too tight, but maybe glad they weren't as they might have burnt. I have not adjusted the valves yet, but most of them are sitting about .042 to .045 or so. Thanks so much for the instructions as to how to set them properly. Book says .027 both intake and exhaust, so will handle accordingly. Thanks again.
