1940 H Farmall. There was a persistent fuel drip off the bottom of the sediment bowl. Tightening the nut under the bowl didn't help. Trying to tighten the fuel line fitting showed that the threads had stripped.
Has anyone used the YT shut off / sediment bowl assembly on an early H ? The description makes it look like the outlet thread is 1/4 NPT. The fitting on the end of my fuel line looks like straight thread and finer than pipe ( 1/2-20 ?). Does it fit without modifying the fuel line ?
Thanks
Greg
YT Sediment Bowl
Thanks
Greg
YT Sediment Bowl
