W.J.Foden
New User
I am trying to free a suspected seized rack on my td 18 injector pump (no diesel delivery to the injectors). I have removed the face plate and the pistons work fine but i can see no sign of the rack.
i am reluctant to remove the pump and it has been stored inside and will probably only nee a tap in the right place but i cannot find a parts schematic,
you can see the rack when u remove the oil fill cover spout. its the piece with the horizontal bolts looking thing that slides back and
forth to turn the other piece . sometime a small tap on that bolt end is all it takes.
Hello W. J. welcome to YT. It seems like you are a fine
proper gentleman with a great pair of initials. I usually
do not do this because YT sells manuals. I am not sure
if they carry the ones I am going to give you a link to.
The link is for a company in Idaho whos main business
is selling repair clutch plates for crawlers. In the link
scroll to near the bottom of the page in the bold dark
blue print are links to manuals for your machine. The
3rd and 4th lines from the bottom of that blue print is a
IH Diesel engine service mans book. Go to page 24
and it will show you the rack. I could have made this
simpler but I wanted you to be able access all the
manuals. A bit up on the page in the small blue print
there is a parts catalog for your machine. You should
be able to get to a parts breakdown of the pump in that
book. Hope this helps.
TD. 18 stuff
