kris Jensen
I would think your carb is the culprit. Sounds like you may have done a half job on it. Did you take the jets out?
Did you ream the small holes/passage ways with a small wire, preferably welding torch tip cleaners. Soak for a while in solvent
and then blast it with air. It the passage and jets that plug up. Carb can look clean BUT watch the little holes in the jets. They
can also look good but might need a reaming.
sometimes takes a lot of patience. BTDT. Kris
