I was cleaning out and old shed and found these items from a W6 I believe. Previous owner had a W6.
Are they of any value/use, or should I just junk them? 90 deg pully drive and pto hydraulic pump.
Well that one item is better known as a Belt Pulley and drive, looks like it's complete, not a lot of value,but the Hyd pump if its good, should have some value! It Maybe from a super 6 !!!!
the hydraulic pump is actually a Charlyn which someone has driven with a chain - more than likely off the belt pulley drive or over the PTO. normally they have brackets and a lovejoy coupling to drive directly off the PTO shaft. They work great and enable an old tractor without hydraulics to pull discs , cult etc with a cylinder/ They were sold to fit any tractor
the belt pulley is definitely not off a Letter Series tractor. they were offered for later tractors without a belt pulley, not sure of all the models but B250 etc comes to mind
This post was edited by mccormicksw4 on 08/14/2022 at 04:19 pm.
the bid on a Pump like that on ebay is couple hundred its worth at least 250 or more thy sell very good single ,twoway,control,pump and resivour all in one 10gpm@ 1000 psi
them charlynn pumps were mounted on most any tractor before hydraulic's came out. nothing saying it is only w6. and that angle belt drive might be from a 460 utility. it mounts to the rear pto to drive it.
