Oil Capacities for a B
Ohio Mike
05-21-2001 12:17:05
I need to replace the gear oil and engine oil in my B. How much of each will I need. Also, I was told to use 10W40 for the engine and 80 or 90W for the gear oil. Any comments? I'd appreciate any wisdom you have to offer.
Dave BN
05-21-2001 21:02:32
 Re: Oil Capacities for a B in reply to Ohio Mike, 05-21-2001 12:17:05
My book says the crankcase holds 5 qt's but seems to me mine takes 6. Oil bath air cleaner takes 3/4 of a pint. Now that I'm reading the book it also says don't forget to clean and reoil the breather cap each time engine oil is changed. Oh oh, think I'll do that tomorrow. Dave BN.
bmich
05-21-2001 15:46:42
I have an original 1948 B owners manual in front of me as I type and it doesn't give any quart amount on th engine oil. It just says to fill oil until it runs out the top petcock when operating on gasoline and I presume you are. It recomends 30 weight for temps above 32 and 20 for temps below. My brother-in-law, God rest him, told me you shouldn't use anything but non-detergent in these old tractors because as the valve guides wear the oil will end up burning in the cylinders and that detergent oil was rough on them. My does this when you first start it up so I've always used non-detergent. I don't know if it does, in fact, matter at all. That's just what I was told. For the gear box etc. the manual recommends you use 90 weight for all temps above zero. Hope this was some help.
