Hi,
I have been running the F-12 around nearly everyday since I got it going. But every time I go to start it it will fire weakly on the second crank but not enough to keep running. Then it will take another 20-30 cranks to fire right off and run great. I am thinking the fuel pump is losing prime. Does this sound right and what could be causing it? I replaced the diaphragm in the fuel pump and am probably going to pull the fuel pump. While I had it off I didn't know what else to look at.
Thanks,
Noah
Thanks,
Noah
