Farmall 450 Fast-hitch Parts Diagram Need
Hi. I've just discovered my new Farmall 450 row crop has a busted fast-hitch. I have an owner's manual but it doesn't show the parts of the fast-hitch. I'd like to see an illustration with names or part numbers. Please help. After that, I'll probably be asking how to remove the part for welding. Thanks, kelly
The side plate that bolts to the tractor with three bolts?. To me that is the first part on and last off. The bolt at the bottom being the worst to get at. One from a 560 down to late 400 will fit. I had one last year I gave away. Good luck. You can pin the draw bar up(stationary) and still use the tractor.
