This tractor has 2 valves and the outside lever, which controls the hitch, has a LOT of back and forth slop in it. I have checked it and the play is above the control lever shaft up towards the linkage and lever that connects to the hydraulic valve. My first question does anyone have a picture of the valves and those linkages? You cannot see in there without taking the dash back away from the rest of the center section. So I want to see what that looks like since I can't remember what it all looks like. Next does anyone have a good lever that goes on the valve? The number is 361650R1. Again I don't remember what it looked like and where the wear can be. All I know it is a REAL pain to take the valves loose, slide them apart and then replace the lever or whatever needs to be done. Back in 2000 and 2001 I had those valves loose or out of there several times to fix leaks and to finally overhaul them to replace the broken garter springs. It was something I did NOT enjoy!! Even back in the shop days it was a pain!!! I think I might have another broken garter spring again on the inner control handle valve. It has a catch in it every so often and at that time it is hard to push.
