international 300 utility
pinball
i broke my throttle lever. been looking for one for a while. saw one on eBay for 59 bucks listed for the int 300 but its different than mine, don't know if that one listed is for a Farmall 300 or not. mine has a 7/16 hole drilled through it with 7/32 dowel pins. the one they show doesn't have the hole like mine so did the utility have different levers or not. thanks
In the link is a 300 utility throttle handle. The IH part number will be 364433R1. The Farmall row crop throttle will have an additional stop tab near the bolt and washer that set in the notches. The tab is about 1/2 in. by 5/8 in. by 3/16 in. thick. Also the on Farmall throttle the hole for the rod it slides on goes through. On the utility the throttle hole is blind and that end of the lever is shaped differently.
Example throttle
