Head Gasket Problem?
Follow-up
David A
05-17-2001 05:37:39
A few days ago I posted a question about my concerns with a rising oil level.
Well, it turns out I was just checking the oil wrong on my Super A. Don't know whether all do this, but if I check the oil cold by opening the upper drain cock, about a quart drains out due to the oil filter canister draining back into the pan. I guess I'll run it bit before checking. The oil is clear so I'm no longer worried about the head gasket.
Tyler (MD)
05-18-2001 03:15:02
 Re: Head Gasket Problem? - Follow-up in reply to David A, 05-17-2001 05:37:39
David,
Thanks for the heads up. Dad's Super A has a dipstick for checking oil level. There's 2 full marks on it. 1 for cold and 1 for hot.
Tyman
gene b
05-17-2001 22:13:04
must have put way to much in when you changed
Great
05-17-2001 14:41:51
;) thanks 4 follow up.
