Re: Farmall 140 Bush hog
Author |
Haas
05-16-2001 15:58:01
If none of the hitch parts get in the way of the shaft, the offset is not enought to bother the universal joints. They actually work a little better and last longer if they have a small offset rather than running straight. You will need an overrunning clutch for the pto. If you do not have that, the inertia of the heavy bush hog blade will push the 140, because is runs off the transmission directly connected to the wheels. The overrunning clutch allows the bush hog to free wheel when you stop the tractor. I still recall the time as a boy that my Dad had to go pull the suburban neighor with 5 acres out of his pond because he could not stop the little AC tractor that had the bush hog on it.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
