Hydrolic Cylinder Stuck
any ideas?
Pete in PA
05-16-2001 12:48:57
Hey Fellas,
The Hydrolic Cylinder on my '40 H mounted
cultivators is stuck. After removing the cylinder
from the tractor to investigate, taking it
partially apart, the push rod seems to be frozen
or something. Any ideas on ways to get it unstuck?
Pete
KURT
05-16-2001 15:09:08
 Re: Hydrolic Cylinder Stuck - any ideas? in reply to Pete in PA, 05-16-2001 12:48:57
Try using an arbor press to push the rod down into the barrel. then use hydraulic pressure to extend it (low flow) work it a little to get it to loosen up and if it is still tight. The rod could be bent. check the piston and rod seals too.
The Undertaker
05-16-2001 12:57:38
Pete:
Frozen? In or Out?
"TU"
Pete in PA
05-17-2001 13:25:48
 Re: Re: Hydrolic Cylinder Stuck - any ideas? in reply to The Undertaker, 05-16-2001 12:57:38
Good point...it's pushed all the way in and stuck. The hydrolics on the tractor won't seem to budge
it at all....
Pete
