826 IH??
Author |
Steve from Tn
05-15-2001 20:19:24
A neighbor is offering an 826 to me. I know the tractor. I used it last year to plant with since my planting tractor was in the shop. It seems to be fairly sound with about 3700 hrs. What can yall tell me about this model? What should I look for. I appreciate any advice you can give me. Thanks in advance.
Mike S
05-16-2001 21:34:07
Re: 826 IH?? in reply to Steve from Tn, 05-15-2001 20:19:24
We have two 826 tractors, check for antifreeze in the oil. Around 3000 hrs the O-rings at the bottom of the cylinders begin to leak . Both tractors had this problem. Other than that excellent tractors.
Matt Sheaffer
05-16-2001 16:41:38
I say buy it. I got one of my own with a narrow front and its one of the best tractors I got.
C.L.
05-16-2001 16:12:52
Buy this tractor! The 826 was one of IH's best models. Too bad they didn't make more of them. Our 786 has the same 358 German diesel. It has 6500 hours and it is still going strong. We use it for everything and never have problems. They are very easy on fuel too. If you live in a cold part of the country, it will start right up if you plug in the block heater for a couple hours. Overhauls can be expensive, but some of these German diesels have over 8000 on them before they need it. 826's and 786's are very similar, so you should have a reliable tractor.
John W.
05-16-2001 05:40:31
Good advice below. Also check the T/A.
R.David
05-15-2001 21:26:48
The 826 is a good tractor. They are powered by a 358 cubic inch german diesel. The engine has a good reputation for power and durability. Overhauls can be expensive. But with the hours you stated, you shouldn't have to worry about that for a while. I would drive the tractor and be sure the trans. was quiet in all gears forward and reverse (No clunking). I would also be sure the parking brake holds well. Transmission work is very expensive. That's a couple of things that come to mind. Hope it helps.
Steve from Tn
05-16-2001 20:40:08
Re: Re: 826 IH?? in reply to R.David, 05-15-2001 21:26:48
I appreciate the comments. I like this tractor. It has an oil leak on the left side that I have to fix. It is a hoss.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Oliver 4340 Plow Setup - by ShepFL. How to properly setup your Oliver 4340 plow plus many tips and pointers that may apply to many other brands of plows as well.
... [Read Article]
Latest Ad:
Would like to find hay table for a John Deere 700 or 750 grinder mixer
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
