buzzinduzzin
- Location
- se illinois
Farmall 450 gas with a belt driven dedicated pump for the steering. Working just fine except for leaks out the input shaft seal & wet around output shaft ( O ring ) . came apart at the plastic shim seam as I had hoped ! did not match mark the two gears to each other ( DUMB ) had a black .007 shim & put in a new .007. {they are clear now } , when putting back together & before I tighten the eight 1/2 bolts it will almost turn a full turn then bind up either direction. I have only disassembled as far as necessary to put O ring in output end & have not dropped any component on the floor & have looked for burrs or nicks . it will turn freely if trial fitted together minus the idler gear, yes I checked the new shim with a mic, any ideas to save me from having to mark the gears & do possibly 22 trial fits to get back to where it will work ??
THANKS !!!
THANKS !!!
