Hello Everyone
About ready to start beating my head against a wall...
We bought a 43 Farmall H back in April. It ran fine for a few days then we began having problems. The tractor start and run and shut off after 10-15 seconds each time. I suspected it was the carburetor. Cleaned it out and continued to do the same thing.
Few months went by before we were able to work on it again..it was basically an ornament in the shed.
Since then I've replaced the distributor cap, ignition coil, spark plugs, and spark plug wires. Still nothing. I tested to make sure I was getting spark to the plugs with a spark plug tester and also took one of the plugs out and observed a blue spark. I know I'm getting spark but how do I tell if its a weak spark? I also tried spraying fuel into the spark plug holes, gave it a crank, and it still wouldn't start.
I have fuel coming to the carb but I'm not certain its "misting" out and making it to the cylinder though. I've read on previous post that I could have someone look while the spark plug is removed and I crank the engine. I'll have to do this tomorrow when it's light out.
I plan on ordering a carb rebuild kit since I suspect the float could be bad considering the 10-15 second run time.
Anyway, any help is greatly appreciated. Thank you in advance!!!
-cazarda
-cazarda
