Doug Kieta
I took my H to a shop nearby to have the oil pump replaced. While it was there, the shop owner noticed I had a 12V alternator conversion, and said that with an alternator, you need to use a voltmeter rather than an ammeter, and so he put a new voltmeter in. He ran a wire from the voltmeter to the ground post on the battery. When I tried to start the tractor today, the battery...a brand new one...was dead. I charged it, and the tractor started right up. I disconnected the new wire. What should I look for to correct the obvious current drain that discharged the battery? Never had a problem with the old ammeter in place.
