F12 Air Filter Assembly
SadFarmall
11-02-2021 01:35:03
Got some more work done on the 1933 F12. Dismantled the radiator,which will need a serious clean and two broken bolts extracted.
I also dismantled the air filter, which has suffered from water in the oil cup and several dents to the body. I have knocked out the worst of the dents.
The steel wool (which I think is called air filter upper screen and air filter intermediate screen) is rusted and breaking up, so I have extracted it from the air filter body. What might be a good replacement? I could use steel wool again, but an air filter foam, which can be removed and cleaned as necessary might be better?
Thanks in advance,
SadFarmall
SadFarmall
11-02-2021 20:30:57
 Re: F12 Air Filter Assembly in reply to SadFarmall, 11-02-2021 01:35:03
Thank you! I'll get some new mesh and see how I go fitting it into the filter body.
SadFarmall
warbaby
11-02-2021 06:42:29
.Type ABC422 into google
Dennis P
11-02-2021 06:34:51
One time I used stainless steel scouring pads.
Dave BN
11-02-2021 05:18:03
I have seen replacement screen for sale. On eBay I think. Try searching there.
Dave
Fritz Maurer
11-02-2021 04:54:49
Just did this on W-12. We gutted a M filter for the media. Will require a little trimming due to the larger diameter.
