B PTO seal info Help!
johnl
05-11-2001 17:39:42
Has anyone replaced the pto shaft seal on a B? My
IH Dealer is unable to cross P/N 48114D. Or is
there any other solution to a leak? Thanks John
johnl
05-12-2001 13:23:04
 Re: B PTO seal info Help! in reply to johnl, 05-11-2001 17:39:42
Thanks DaveG & DaveT, This gives me some leads, I
was deadended.
Dave G
05-11-2001 20:43:49
I ordered 2 today from Davis Farm Equipment in Tipton, IA. Phone 319-886-6175. I had to dig the old one out and it wasn't fun. I didn't have a puller big enough to get gear off and remove shaft. New ones are thinner but work just fine.
Dave T
05-11-2001 20:50:53
 Re: Re: B PTO seal info Help! in reply to Dave G, 05-11-2001 20:43:49
What gear are you talking about? The pto seal is installed in the casting around the pto shaft. It's just a tap thru fit, are you talking about something else, or am I missing something?.Dave
Dave G
05-13-2001 07:32:01
 Re: Re: Re: B PTO seal info Help! in reply to Dave T, 05-11-2001 20:50:53
I'm talking about the gear inside the tractor on the PTO shaft. I had the whole PTO assembly off (doing other things) and wanted to get the PTO shaft out so I could tap the seal out instead of dig it out. The PTO gear on the inside is really tough to get off, in fact I couldn't. After I wrecked my puller I decided to stop.
Dave T
05-11-2001 18:19:53
I changed mine on A's & B, I got the seal either from Napa, or the local bearing and seal store. I've got them from IH too. Maybe the guy at the IH store is incompetent...the number is: National 48954D. The new ones are only half as thick, so I bought two of them, and doubled them up. I also used #2 permatex to seal up the sleeve. It seems like a screwey design, (the sleeve), but with a little care, they won't leak...
