140 farmall
khouse6
changed water pump on 140? coolant was leaking from water pump. now, i do not see any leaks. coolant is getting gone. does not seem to be coming through the exhaust. hmmm what should i look about now?
Might have to top off the radiator two or three times before is stays full. Are you gaining oil, as in the fluid is ending up in the oil pan?
Dave
Unscrew the drain plug but dont take it out. If there is anything down there, it will start dripping before the last thread is disengaged.
