Super A Head Gasket Problem?
David A
05-11-2001 05:15:53
I noticed a little oil scum floating on top of my coolant and starting thinking head gasket. I opened the upper engine oil draincock to see if the oil level was rising and sure enough it was high. It it over a quart high! (engine cold) Last change I put in the correct 5 quarts.
Question; am I checking the oil level correctly or is this excess due to drain down of the oil filter? Maybe I should warm the engine to refill the paper cartridge type filter before checking?
Thanks,
David
haas
05-11-2001 13:54:06
 Re: Super A Head Gasket Problem? in reply to David A, 05-11-2001 05:15:53
If your oil is clean or even black, but not milky, then you do not have coolant in it.
Glenn(WV)
05-11-2001 06:45:21
If you have hydraulics, your hydraulic pump might be leaking hydraulic fluid into the crankcase, causing your oil level to be higher than normal . . .
David A
05-11-2001 06:56:58
 Re: Re: Super A Head Gasket Problem? in reply to Glenn(WV), 05-11-2001 06:45:21
Thanks Glen,
I had not thought of that possibilty. I'll check the touch control oil level.
Daniel
05-11-2001 06:44:31
Did you change the filter with the last oil change? If so, there could only be 5 qts. total in the crank case. If there is a quart of coolant in the motor I would think the oil would be real milky looking, also the radiator would be a low. Just a few thoughts, Daniel.
David A
05-11-2001 06:54:39
 Re: Re: Super A Head Gasket Problem? in reply to Daniel, 05-11-2001 06:44:31
Thanks Daniel,
Yes I did change the filter last time and set the oil level with the engine warm so the filter was full.
The oil is clear like new oil and the coolant level has not dropped. I'll try warming it up and then look at the color of the oil.
