Paul 300 U
I've had this tractor for about a year but haven't actually run it much while I try to fix the power steering. (More on that progress in another post).
While testing today I had 3 leaks.
1. At the glass bowl where the gas line screws goes into the brass fitting is leaking gas. I don't see a washer, seal or o ring. I don't want to over tighten. Can I use plumber's tape?
2. The steel line that runs to the oil pressure gauge had electrical tape over a pin hole. Not surprising the tape isn't holding. A quick search shows plenty of gauges but no line. Where can I get a replacement. Anything particular I need to be aware of?
3. I notice what I think is/was hydraulic fluid leaking at a steady rate out of this hole under the tractor. It's on the bottom left in front of the foot pedal plate. (See pics) Hoping this is not serious, maybe just a missing plug but it's definitely not good. Please let me know what you think and how I can repair.
Thanks for your help with these items. It's appreciated. Paul
