HobbyFarm71
New User
I have a Farmall 450 that is new to me. I recently have been having issues with the battery going dead. The last time this happened it sat for less than 24 hours and the battery was flat as a pancake.
My Amp meter was non functional so I replaced it with a new one from the dealer. On start I noticed that it never registered a charge.
This tractor is 12v positive ground and still has the original generator. I took a look at the regulator and gave it about a 90% chance of being the problem. It was all rusted and corroded and the contacts at the large coil were sticking. My new amp meter confirmed this as it registered 60 Amps of discharge.
Now for my question. Once I replaced the voltage regulator and started it back up the amp meter registered a large amount of charge happening. >+40 amps. After about 5 minutes the meter started showing a slight discharge. (About the same you see with key on, engine stopped.) The meter never registers anything other than this slight discharge for the entire time of operation.
At next start, I will see the large charging activity again and this lasts 5-10 minutes. The charging amperage will vary with engine speed. At some point, all charge activity stops and all I see is the slight discharge.
Is this normal?
Thanks in advance.
Is this normal?
Thanks in advance.
