Needing a hydraulic bypass block for Farmall 100
ShawnAgne
I'm needing a hydraulic bypass block for a Farmall 100. I assumed I could find them for sale at various places but I haven't. Does anyone know where they can be found or have one for sale?
Thanks in advance.
Is this what you are looking for? See link. I am not that familiar with the models smaller than an H. I just searched for it but used Super A instead of 100 because they are virtually the same tractor. There are just quite a few more Super As. If you look close at the print on the paper it says 100 is included in what the part fits. What does this block allow you to do?
The block
Yes it is thanks!! I was searching under Super A, Super C, etc. and all that was coming up were Ebay auctions that were closed. I knew this was going to be like stuff in the pantry that I can't find and wife looks in and sees it instantly.... LOL
I'm wanting to add power angle on my A60 blade on my 100 like i have on the blade on my cub. So this lets me add the control valve to operate that. Also if I was going to run an IH1000 loader you need one of these to control it.
Thank you very much!!
The block IH made worked on both the Cubs and the Super A/100/130/140. I believe the one TM Tractor sells is identical to the original.
