grandpa Love
Found this in a barn today. I'm guessing injection pump..... What tractor? Value? Probably weighs 40 pounds!
It is a diesel injection pump from a gasoline start diesel run engine. Several models and displacements were made, so matching the part number will help match it up. No one makes them anymore, so it has some value even if it is a core. Jim
Likely a WD9 ihc A pump. could be from a power unit as well. The A pumps were early production, B pumps later. Bosch Pumps were also used. Jim
That could go on and old M D or even a TD 14 as it all depended on fuel rate and gov. set up Like Jim said later ones used on the 450' and super W 's were the B . My old 450 D ran a B pump that came off a T D 14 Dozer and with a few twists of the screw i could run at 49 hp or i could clear a fifty acre field of skeeters and stand a foot of fire out the pipe in broad daylight . along with lots of coal rolling . Enough coal rolling that twice the local fire dept was called once for a barn fire when we had it on the silage blower blowing silage up and 80 footer and once for a field/ forest fire when were were plowing a filed back in a woods someone saw the smoke billowing above the trees as there was not just one turned up 450 but two plowing and here came the fire trucks .
At least it looks like they had the good sense to cap and plug the fittings. Might even be a good rebuild from years ago. Fits the IH gas start diesels.
Post it over in the photo adds left side of page and I bet you will get a buyer. Or over on RPM construction equipment.
