Aftermarket 3pt with cylinders over axles
BarnyardEngineering
09-18-2021 17:46:50
I picked up an aftermarket 3pt today that appears to have the cylinders mounted over the axles. Any idea who might have made it without pictures?
used red MN
09-19-2021 09:00:39
 Re: Aftermarket 3pt with cylinders over axles in reply to BarnyardEngineering, 09-18-2021 17:46:50
I have seen those type and look to me to add a fair amount to the difficulty to operator access to the operating station. I web searched for images of Farmall 3 point conversion hitches and came across one in a Red Power thread for a C. It has links that run up to the hydra-touch rock shaft for lifting. It appears the mfg. may have just added side cylinders over the axles to allow this design to work on models without a rock shaft. Other than for a C I always wondered why you would purchase this style of a 3 point when others were available with the cylinders tucked nicely out of the way behind the rear axle case. Probably more about local availability and price who knows. Sorry I did not help at all with the brand.
