Shopteacher
New User
Hi guys,
Thanks for the help with my questions thus far. Aside from the hiccup with the block and head, things are progressing nicely and the kids are doing a great job and are way more interested than I
thought they would be. I am to the point where I need to order parts to keep the project on track. A large part of the parts that are going to need to go into this are bearings and seals. I am going to
try to order everything through a bearing/seal wholesaler. I have had good luck with Accurate bearing out of Chicago. I'm guessing if I order through a dealership, prices will be crazy. I restored a John
Deere B in high school and bought everything from John Deere because I didn't know better. After that experience, I came to the conclusion that the cardboard john deere uses for their packaging must be
extremely valuable. Anyway, how do I 'cross' bearings from what is on the tractor to something more modern? I've been following Squatch253's build on YouTube, and he has bearing and seal numbers that he
crossed from the OEM parts. I've written down the parts numbers so far, but not sure if I have the time to watch every video to get a snippet of the parts numbers he has. I've tried commenting on his
videos to try to reach out to him, but I haven't had any luck.
Also, a lot of the seals on this machine are doubled up. From what I gather, Farmall had extra wide seals when this came from the factory but those aren't made anymore. So, people are doubling up
standard seals. People say you need to grease up one of them as it will see no lubrication. Is this what you all do? My next post will be how to determine if a sealing surface is adequate or if it needs
attention because there are some spots that I think might need a little weld/machining to bring them back. Thanks guys!!
Andy
Andy
