I am trying to remove the vertical shaft for the range shifter. There is play between the shaft and the bottom arm. Hoping it is just the woodruff key that is worn. I removed all the linkages and the retainer on the top of the shaft. I also removed the roll pin for the "rooster comb" looking thing just above the lower lever, and the bolt for the lower lever. I cannot get the shaft out though. Is there something else under that transmission cover that is holding it in? I can get it far enough up that I can see the o-ring, but no further. I can spin the rooster comb and get it to move up and down a bit. I am thinking maybe the key is bound up, but don't want to continue beating and prying if there is something else holding it.
