Picked up a B awhile back and trying to clean it up a bit. I would like to replace the transmission cover gasket, do I just shift it to neutral or put it in a certain gear ? 2nd question, it has magneto on it, so when I got it, it had a rusty toggle switch on it for on/off, I had a mag switch as I call it that every Farmall had on it from the factory has two lugs on in, I hooked one wire to the magneto and the other to ground, try pull the knob out to start it and it doesnt fire, push the knob in and it starts right up, I turned the wires around and it made no difference. Whats wrong with this ? Thanks all !
This post was edited by JimmyDean on 09/12/2021 at 07:47 pm.
