Carburator fuel bowl dain plug size on a farmall H
Raner
I'm fixing to order some stuff online and thought of adding a "Drain Cock" to my 1949 farmall H's carburetor fuel bowl drain but the tractor is 60 miles away, So I figured someone here would know the correct size of the drain plug. I'm thinking it's 1/8 pipe tread but I'm not sure...Thanks
Yes. 1/8" pipe plug. If your H came from the factory as a gasoline burner, it will have that 1/8" plug. If it originally was a distillate or kerosene burner, it will have the brass drain cock, but still with 1/8" pipe threads.
