mr.precision
Learning as I go about my new (to me) 1967 Cub Lo Boy.
Completed a service as the tractor had been sitting for some time before I got it.
One unusual thing I noticed is that when the clutch pedal is pushed in, the motor slows down quite a bit. Does it hot or cold. Clutch pedal free play is correct and clutch works just fine. Haven't seen this on any other tractors I've had.
Is this common? If not, any ideas on what to check? I greased the fitting on the bottom of the clutch housing, but have not removed the plate there to look at the TO bearing.
Nice old tractor that I don't want to overlook something and tear it up.
Thanks in advance
Thanks in advance
