My 47 Cub has been really hard to start most of this summer. Its 12 volts with a J4 mag so cranking is no problem. Tractor acts like it want to start and fires occasionally and if I crank it long enough it
will eventually start and run fine. Sometimes I can't get it to start until trying again the next day. I'm trying to figure out if I have a weak spark or a gas problem. No problem getting gas to the carb.
Everything is tight on the carb and manifold gaskets. When I got the tractor a few years ago it had low compression so had the valves done and shop went through the entire motor checking specs. That was a
about 4 years ago and motor doesn't have a lot of hours on it. When I got it there was a real cobble job of wiring and the tractor had been set up for an external coil and had a condenser attached outside the
mag so I replace the mag coil, points and condenser and went to a single wire alternator. I also replaced the carb as original had a lot of physical damage. Carb is IHC carb. Tractor started and ran great
after that and runs great now if I can get is started. I did try a different condenser I had in the drawer (previously used) and thought it helped but a few days later nothing had changed - still hard to
start. I was finding oil inside the cover where the points are and in the cap so I changed the oil seal at the front where the mag attaches and cleaned all the oil from the points area and made sure points
were clean. I hear the impulse coupling working. I'm looking for what else to look for. Mag is back together correctly as eventually the tractor starts and runs well. Looking for other ideas.
