Counter Shaft To Belly Pump Removal
We have a stage one Super M with a M&W live pump. The belly pump reservoir is used and the belly pump coupler input is blanked off. The coupler on the transmission is not used but the seal is leaking. My question is can the end cap off of a stage two transmission be used here after removing the coupler?
Yes if you use the washer and nut used with cover before installing the cover that came on a tractor with one.
Thanks for that info. Ill go in search of a washer and nut to
replace the coupler. I plan on replacing the seals in the
housing with a freeze plug if I dont find a cover.
