Question on a hone
Dave H (MI)
Since I do not have one and (see picture in my last post) there is some raised rust on the sleeves, is this what we are talking about? Comes in various sizes and grits. Reviews seem pretty good. Just question is it the right tool, what grit(s) to order and how to size it. Like, if the bore were 4 do I want that or the next size up?
Hone
you need just the cyl. deglazer hone. its puts spring pressure against the 3 hone stones to cyl. wall. plus it can be used for different size bores.
another thing u could do is once you have cy's cleaned and blown out then let sit for a day with light oil , guess i should say ATF, as soon there will be posts saying to use that. it can be mystery or snake oil is what i like to use. from what i see its not stuck too bad. give each piston a few raps and then once broke free just keep turning it and blowing the rest of the rust out. im sure it will be ok with out pulling pistons. but its your choice. if you get it running as is just put it to work under a hard load to free the rings up. along with some 2 cycle oil in the gas.
