Super M starter switch
This Super has the foot lever to press the starter button. On the back it has two terminals. I've forgotten again. I didn't tear this down and it's been so long since I've done a farmall I know one is for the starter cable but what connects to the other post Thamks again.
The battery cable to your battery negative post if you are
setting it up as original with a positive ground. If you are
going negative ground it will go to the positive battery post.
If using the stock on off switch and lights there will also be
a wire going to a terminal on the amp gauge to that
terminal on your pedal switch as well.
(quoted from post at 00:42:16 09/01/21) The battery cable to your battery negative post if you are
hanks for responce
