Southtowns27
Hey guys, I've got a new to me 140. I was going over the machine when I got it home and noticed that the charging rate was low. The wiring was less than stellar so I just rewired most of it. The charge rate is still very low. With only the ignition operating, it takes a *very* long time for the voltage to creep up over 13. With the headlights on it discharges. The generator motors when I touch a jumper between the armature and battery terminals on the VR so that tells me the generator itself is good. The commutator looks great and the brushes aren't stuck in the holders. I cleaned all the grounds between the generator case and block and VR and mounting bracket with no change. The VR itself looks relatively new and the contacts aren't pitted. I feel like I'm missing something simple here. What makes the thing kick up to a higher charge rate? Is it possible that my regulator is bad? What else should I check?
