Dave H (MI)
Tractor is back together, without the clutch. Soaking the cylinders currently.
I gots a little confused on my last post. The tractor went together super easy without the clutch. The manual refers to a second manual which I do not have for clutch issues. So I have to ask...the thing TV and Jim N were talking about where they compressed the clutch fingers and blocked them with a nut. Is this for when you hang the clutch on the splined shaft or when you install it on the fly wheel. This was really confusing me because I just put the clutch disk in the fly wheel, then put on the pressure plate. I start all the bolts and then work around in rotation and it pulls the clutch fingers down. Am I doing this wrong? Need clarification.
